586,069 active members*
3,619 visitors online*
    Hello everybody
    Has anybody experience with the programming of Sprint65 or Sprint 90 with Siemens 840D SL?
    What is programmed at MS1 spindle does that also run on FS2 spindle?
    Or do I have to reflect it or change it somehow??
    Thanks a lot
    Regards GITAL
    hapo Guest
    Many roads lead to Rome...
    In Shopturn usually the zero point for the opposed spindle with reflected Z axis is used and the opposed spindle is turned into the master spindle.
    Like that, the program for the main spindle is now executable on the opposed spindle.
    Of course the tools need to be created and set up accordingly...
