586,329 active members*
5,087 visitors online*
    Jun 2007
    31
    Hello people!
    Is it possible to change rotation speed as I’m feeding from point A to point B?
    I’m thinking of splitting the path into pieces and then define the new speed after the certain time period (for example, 1sec)
    Who has ever made something like this?
    Thanks in advance!
    Dorothea
    Paranuit Guest
    Your suggestion is very good, because it’s impossible to make changes inside of one clause.
    Sep 2002
    1956
    You can make it with synchronization. Just describe the feed selector switch depending on the path or the time period.
    I have a program where 4 (or more) different speed changes are turned on with synchronization actions, and you can program acceleration and dwell period for each speed yourself. Unfortunately I can’t post it till the next Tuesday. I’m on vacation at the moment.
    Oct 2005
    659
    I can’t imagine it. What will the contour look like? If the speed is changed all the time… The spindle needs time to adjust to the new speed.
    <span style='color:blue'>Mit freundlichen Gr
