586,103 active members*
3,737 visitors online*
Results 1 to 6 of 6
    Jan 2008
    18
    Hello!
    I hope that someone can help me!
    When I reference the C-axis
    G74 C0
    is obvious.
    Does the reference point of the spindle refer to the point where it stands at the moment?
    Or is it defined in a certain turning position?
    As in G18 in X and Z
    Example:
    I wrote G74 C0, later I reference it again. G74 C0.
    Is it then the same position as in the first call?
    Regards, lolo
    Hi lolo26!
    Yes, G74 always refers to a certain point. If it wasn’t so, that would be bad!!!
    Christian
    Jan 2008
    18
    Ok.
    Thanks a lot!
    Jan 2008
    18
    Hello again
    I have one more problem with the C-axis.
    I want to have holes in plane surface. C-axis is chosen and diameter position of the holes is established.
    Problem:
    Details of the straight line, where exactly is actually C+0?
    +X or +Y and the turning direction.
    And what is about TRANSMIT? The same position?
    I need help!
    Regards, lolo
    Aug 2002
    293
    Hello
    I’d say, in your case:
    C0 is in the X+ axis
    C43 and C260 or C-100 and the X value.
    Rotation direction of the spindle is clockwise.
    Y value isn’t considered.
    What about transmit – I don’t know…
    Regards, Peter
    Nov 2004
    2484
    I would program it the following way:
    C=DC(43)
    and
    C=DC(260)
    Turn in the shortest way!
    To save time!
    <b><br />Das dringendste Problem der Technologie von heute ist nicht mehr die Befriedigung von Grundbedürfnissen und uralten Wünschen der Menschen, sondern die Beseitigung von Übeln und Schäden, welche uns die Technologie von gestern hinterlassen hat.</b><br /><br />Dennis Gabor (1900-79), ungar.-brit. Physiker, Entwickler der Holographie, 1971 Nobelpr.
