Originally Posted by
krymis
"I am not sure what circuit of mine you refer to, but if it is using a 2n7000 for a buffer, then if you use this method of buffering the Printer port, instead of a breakout box, then the 2n7000 can drive a SSR or ordinary relay to switch on what ever you want.
If you need a 5v or 12vdc supply for the SSR you can use one of the HD connectors on your PC power supply.
Al."
What is the HD connector he is talking about?
HD = Hard drive connector on the PC power supply.5v & 12v available, although the 5v has the most capacity (Current).
Al.
Albert E.
