586,036 active members*
4,071 visitors online*
    Dec 2007
    38
    Arrow
    Hello
    I have a problem with zero point adjustment.
    Example:
    2 cones have to be turned. The controller can’t turn them using roughing cycle.
    So I wanted to move the zero point in X: the first cone is turned without problems, remain of the contour not. As if G54 were only valid for the first cone.
    The program:
    R1=10
    T1 D20 M4 u.s.w
    N100 G0 X14.564 Z0
    G1 X25.5 Z-25.5
    Z-40.5
    X18.192 Z-66.5
    G0 X30
    Z0
    G54 X=R1
    R1=R1-1
    @100 K-100
    M30
    Has anyone tried that?
    Regards, 0815Marvin
    Nov 2004
    2484
    I’d make it as follows:
    R20=10
    T1 D20 M4 u.s.w
    N100 G0 X14.564 Z0
    G1 X25.5 Z-25.5
    Z-40.5
    X18.192 Z-66.5
    G0 X30
    Z0
    R51=R20 L654 P1
    (NULLPUNKT X SCHREIBEN)
    R20=R20-1
    @100 K-100
    M30
    R20 because the parameter isn’t used by Siemens cycles.
    Here’re the remaining zero point data:
    R51=0 R52=-200 R53=-390 L654 P1
    R51=-350 R52=-200 R53=-390 L655 P1
    R51=-200 R52=-200 R53=-390 L656 P1
    R51=-50 R52=-201 R53=-391 L657 P1
    Here X=R51 Y=R52 Z=R53
    NP G54, G55, G56 and G57
    I don't know whether it works, co be careful!!!
    Boern
    <b><br />Das dringendste Problem der Technologie von heute ist nicht mehr die Befriedigung von Grundbedürfnissen und uralten Wünschen der Menschen, sondern die Beseitigung von Übeln und Schäden, welche uns die Technologie von gestern hinterlassen hat.</b><br /><br />Dennis Gabor (1900-79), ungar.-brit. Physiker, Entwickler der Holographie, 1971 Nobelpr.
    Nov 2004
    2484
    If you don't have L654, apply the following as a sub program:
    %SPF654
    (NULLPUNKTE LADEN G54)
    @714 (ZWISCHENSPEICHER LEEREN)
    @430 K1 K1 K0 R51 (X-ACHSE)
    @430 K1 K2 K0 R52 (Y-ACHSE)
    @430 K1 K3 K0 R53 (Z-ACHSE)
    @430 K1 K4 K0 R54 (4-Achse)
    @430 K1 K5 K0 R55 (5-Achse)
    M17
