I have a couple of options to choose from and was hoping someone could help me choose the best of the two. I have read the switchers are not "ideal" for stepper drivers but I have these IOTA DLS-30 units available (12V 30A, Ripple and Noise = <50 mV rms) I know 30A is overkill and series wiring may work isolating one of the chassis grounds. But is not something I am comfortable with as these are not dirt cheap units. The second is two old battery charger transformers 12V 6A and from what I have read this would be a better option. Ok heres the but, they seem to have a center tap with one diode (half wave I assume) and I need to know if in series how these diodes will affect the output and where to place the other two diodes or can I just put the outputs through a full wave Br Rec I have already? I would love to just get rid of the existing diodes so this would be easier for me to understand if thats possible can I just jumper where the diode is and remove it?
Also if it matters I plan on using the Zylotek drives and motors. Because as much as I would love to try and build my own drivers overall success is something I would like to achieve with as little singed hair as possible!
Thanks in advance
