586,052 active members*
3,940 visitors online*
Thread: Helix path
Results 1 to 6 of 6
    Nov 2004
    35
    Unhappy
    Hello everybody
    I have to move off the lateral surface of a cone with the aid of Helix.
    The conic section has an opening angle of 45° and is 150 high. Could you explain me how I should program a helix with enlarging radius in ShopMill?
    I need help with syntax of helix description. The cylindrical helix is simple, but I don’t know how I can get a continuous enlargement of a diameter.
    Salmen
    <span style='color:blue'><span style='font-size:14pt;line-height:100%'>Ich liebe New York&#33;&#33;</span></span>
    Apr 2002
    5003
    Activate tool correction and then offn+ or – depending on hat you need. If it goes larger, than rather –
    Nov 2004
    35
    @uli12us
    Sorry, "offn +" "offn-" ?????
    Apr 2002
    5003
    Exactly as you can input offn=20, offn=-20 also works even if have only a 5-cutter.
    Nov 2004
    35
    I know only the mask in ShopMill for programming of a cylindrical helix. Can you explain more exactly what you mean? I don’t understand. Could you write the whole thing for a helix with output diameter of 25, slope of 0,05 and diameter enlargement per rotation 0,08 with length in z 150.
    Thanks a lot
    Salmen
    Sep 2002
    1956
    It would be something like this:
    $TC_DP1[1,1] = 120
    $TC_DP6[1,1] = 0.001
    n10 g1 x30 y0 z0 f10000
    n20 g42 x12.5 d1 t1
    n30 g3 i-12.5 j0 turn=2999 z150 offn=240.001
    n40 g1 g40 x40 n50 m30
    z150 and slope of 0.05 result in 3000 rotations.
