Hello CNC experts,
I need your help!
I have EMCO CNC turning machine E65 with Siemens controller 810D
There’s a barrier around of the tailstock that I can’t change. The max. path is set to 535mm, but I need more because I have to drill inside, I get the 10720 error: software limit switch. I’d like to know where I can change the value 535mm. There must be a parameter where the value can be set. I need your help!
Regards
Jurgen
