586,069 active members*
3,463 visitors online*
    septembre83 Guest
    Hello
    I have already posted this topic under manufacturing process because I don’t know if it’s possible to program this special thread with shopturn.
    How could I make a special inside/outside thread like the one in the attachment at CTX320 with Siemens 840d/Shopturn? Material is St52, number of units – 100. What tool should I use?
    Greetings
    Septembre83
    Hello
    Why wouldn’t it work with ShopTurn? You may define your pitch under “p”.
    You just need the WSP with the relative form. Someone could make it for you.
    Regards, InTex
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
