586,069 active members*
3,410 visitors online*
    Hello fans, freaks and those who know everything about ShopTurn!
    Unfortunately, I know that input masks don’t accept any R-parameters. But how is it possible to use the data programmed in separate work steps (like diameter, length, angle, X1 X0 etc.) in a DIN-line? Where are they stored?
    Greetings from mountains and thanks in advance
    Franz
    Karlsson Guest
    Hello and good morning
    The R-parameters aren’t enabled under ShopTurn. Only in the pure ShopTurn/ DIN ISO.
    Greetings
    May 2007
    377
    Greetings
    Hello
    Here is an example for editing with R parameters
    Regards, Fred
