586,062 active members*
4,429 visitors online*
    Hello everybody,
    I have a spinner machine with Shopturn V.7.20…
    I tried to mill a longitudinal slot on the rear side but I had several problems:
    First of all, I couldn’t construct an angle deburrer in Shopturn and the control didn’t allow
    a travel path in the cycle after n+.
    So my question is how trick the controller so that I can define a angle deburrer and then debur on the rear side. Does that only work with G code - if so please give me a solution.
    Would be very grateful for your help
    Greetings from Barnim
    <b><u><!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto--><!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro--><!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo-->Ich weis nicht alles, ich lerne viel, <br />aber leider wird einem selbst das <br />lernen heute erschwert<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--></u></b>
    Hello everybody,
    Have you ever tried to program it freely- not in a cycle ?? Also you could state a different milling machine instead of an angular mill- but then use you angular mill and write your cycle according to it.
    Greetings
    enrico
    Greetings
    enrico
    Hallo enrico,
    I am not so familiar with the transmit programming in Shopturn. Also the machine has no proper y axle what I believe makes everything even more complicated.
    Just in case I need it would you be able to show me the process in G code?
    Would be very thankful!
