586,069 active members*
3,405 visitors online*
    Hello
    I have a Saeilo TSL 500 with Shopturn 810 controller.
    How can I increase the Tool memory?
    I have around 70 tool spaces available at the moment.
    Many thanks in advance
    Regards
    Dirk
    hapo Guest
    70 spaces are not enough for you?
    OK! Then you should contact your machine manufacturer.
    A change of tool spaces would cause a memory formatting. I would not recommend to change the machine parameters yourself if you are not unsure about how to do it.
    It would probably result in a complete data loss.
    So get your hands off!! Contact your manufacturer and get an quote.
    Then you can make the decision if 70 spaces is not enough!
