586,567 active members*
3,613 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Chopper drive max voltage vs max voltage of Nema23
Results 1 to 6 of 6
    Jul 2014
    9
    Hi guys,
    I'm looking at building an OX CNC but wanted to upgrade stepper motors a bit.
    Looking at 269oz.in Nema23 - Nema 23 CNC Stepper Motor 2.8A 1.9Nm(269oz.in) 23HS30-2804S - US$
    to drive x, y & z
    I thought to place a heavier nema23 on z as well since I'm planning on getting one of those 6Kg (13pounds) chinese spindles later on.
    That particular stepper motor is a 2.8A, 5.4mH (inductance).
    If I follow Gecko website info about amps and max voltage I get:
    (3*2.8A)*0.67=5.628A required for all 3 steppers.
    max voltage= sqr root of Inductance * 32
    max voltage= 74.3v
    Now, I can't find any chopper drivers reasonably priced that can handle 5.5A in total, or 2.6A per axis as well as handle max voltage of 74.3v.
    Am I just finding ****ty stepper motors or am I trying to use larger Nema23 steppers which DIY scene has no drivers for?
    Any input is appreciated.
    Id most drives accept around 25v that means my Nema23 are going top be almost useless since theyneed 74v, which means I need weaker steppers, a lot weaker.
    Mar 2004
    1806
    Re: Chopper drive max voltage vs max voltage of Nema23
    Regular Gecko drives (20x variety) are rated to max 80V and 7 amps if I remember correctly!
    I have some original 201's on my router running NEMA23s with no problems.
    Art
    AKA Country Bubba (Older Than Dirt)
    Jul 2014
    9
    Yes they are very nice but also very expensive for my first project.
    I'd rather get something cheaper and more open source if possible and once I get my basics straight then I can start improving on equipment.
    If you guys think they would be my only good option for driving Nema23 at max voltage then Ill save up and buy them.
    When you try to spend as little as possible, you'll rarely end up with a perfectly matched set of components at thelowest possible price.
    Just find some motors with a lower inductance, and use a Gecko G540 and 48V power supply. While that still be more than you were planning on spending, it'll probably give nearly double the performance.
    NEMA23 282oz/in 3A Stepper Motor
    If you do get that Chinese spindle down the road, I think you'll find that it's much too heavy for the lightweight OX machine, and you'll see considerable flexing in the gantry.
    Jul 2014
    9
    Alright, I'm convinced, I'll get the G540. It was just my first CNC project and I was afraid I'd screw something up, but by the looks of it, G540 will not let me screw up most of it by automatically switching off if there are problems.
    One thing I keep finding at a couple of stores is soldered potentiometers on cables from steppers to G540, like this:
    EZ-G540 - Set of 4 - Soigeneris.com
    Isn't G540, like any stepper driver supposed to regulate current on its own? If so why the manual limiting in stepper cables?
    P.S. that is a crazy good Nema23 with almost unbelievable Inductance value Thank you, good find.
    Those aren't limiting the current. They are on a different pin, and tell the G540 what the motors rated current is.
  1. Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
    By Dirky in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2021, 06:39 PM
  2. DualDC - HV bus over voltage or under voltage fault
    By legendboy in forum CNC Machine Related Electronics
    Last Post: 01-25-2012, 11:25 PM
  3. chinese drive voltage compatability
    By dix2111 in forum Phase Converters
    Last Post: 09-05-2010, 06:43 PM
  4. Num servo drive - onder voltage
    By flannman in forum DNC Problems and Solutions
    Last Post: 04-20-2009, 09:38 PM
  5. What dc voltage to use on rutex R90H drive
    By BOB F in forum Rutex Products
    Last Post: 11-28-2005, 05:22 PM
