Attachment 242018
YAG 500W laser cutting machine,with 750W YAG laser power,it was suit for cuting metal sheet,such as stainless steel,solid steel,aluminum,copper,brass and so on.The cutting pression is very good,suit for accurate cutting works.
Applicable material:
Stainless steel, mild steel, carbon steel, , spring steel, alloy steel,iron, copper, brass, aluminium, titanium, metal sheets, metal plates, metal pipes, metal tubes, etc.
Applicable industry:
Sheet metal processing,metals ironware components and parts, chassis,racks & cabinets processing, kitchen ware, food machinery, cooking utensils, metal crafts, metal sign letters,elevator panel cutting,etc.
Main introduction:
1.Equipped with medium power lamp pump laser, flexible cutting any design within working area 1300mm*2500mm.
2.Suitable for thin metal plate specially large cutting, the processing speed is quick, the cutting precision is high, coordinate following dynamic focus system, it has realized different thickness materials automatic focus cutting.
3.The machine working table with ball units design for easier loading and unloading, it saved the manpower greatly.
4.It also can punching and cutting for metal pipe and tube if with integrated or detached rotary system.
Parameters:
Machine Model YAG steel laser cutter SN-750W Laser wavelength 1064nm Laser pulse frequency 0.1 - 500Hz Width of pulse 0.2 - 20ms Working current 100 - 400 A Laser rated power 750W Laser power source 18kw Chiller 5kw Working size 1300*2500*50mm Processing precision 0.05mm/min Repositioning precision 0.05mm/min Min line width 0.2mm Located apparatus Red light direction Way of air protection Coaxial Suitable file format dxf, ai, plt Driving way Japanese servo motors Continuous working time 24h Max cutting thickness (Carbon steel) 8mm General power 12-20KW Electrical source voltage 380V±10%/50Hz/100A Spare parts Xe lamp, water, auxiliary gas(N2, O2) Grade of laser Class IV Packaging size Machine:450*248*155cm
Control box:140*140*150cm
Chiller:130*120*150cm
