Hello
I have the following problem: I have a work piece with undercut. In order to mill it, I have turned the coordinate system 10 degrees in X and -10 degrees in Y. However when I measure a line, then I get a distortion of 0,15 degrees on the Y turning axis, the angle in the X turning axis would be correct.
Now I want to mill with a tilt angle and enter the 10 degree in the A and C axes.: the work piece runs into the contour. I don’t know where the error lies, when I roll the work piece back in the reversed order, then the work piece is inclined- exactly the 0,15 degrees.
Can anybody give me some advice?
