Does anybody know of a site that has a circuit for a mach 3 compatible chrge pump?
Here are a few links and suggestions on a thread I started about a month ago:
http://www.cnczone.com/forums/showthread.php?t=22287
I'm working a charge pump in between some other projects,
HayTay
HayTay
Don't be the one that stands in the way of your success!
HayTay,
Have you made any progress with you charge pump?
Eric
Mach in thier instructions has a charge pump circuit that works. I have used it and it is pretty simple
mike
There are a couple of chargepumps on the Mach3 site http://www.artofcnc.ca/ChargePumpSafety.pdf designes by Mariss from Geckodrive. They look pretty simple, and having read posts from Mariss out here I would definitely trust anything he says. He really knows his stuff well. So if he drew these you can be sure that they work.
If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
Steven
I broke down and bought on at cnc4pc along with a couple of other boards.
Thanks to all, Eric
Steven
