586,459 active members*
3,231 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Component part – AutoCAD
    Apr 2006
    91
    Hello people
    Who could explain how I can export a component part (e.g. a lever) from Inventor to Autocad?
    I need to have the contour of the lever as a dxf-file then to refer it to another firm, so that they can cut this laser.
    Or is it possible to create a dxf-file directly from Inventor?
    Thanks in advance
    Apr 2002
    5003
    Just save as and then choose DXF. Inventor has to be able to make also DWG. Just in case if you need to change something fundamental in ACAD.
    Jul 2002
    332
    Hello
    Here’s a screenshot of where you’ll find it
    Bye
    Burkhardt
    Jul 2002
    332
    Hello
    I forgot to say:
    It only works with drawings and sheet blank (see Inventor’s help)
    Bye
    Burkhardt
