586,065 active members*
4,842 visitors online*
IndustryArena Forum > CAD Software > NX CAD (UNIGRAPHICS) > Converting of NX4 .prt Into .dxf
    Hello everybody
    I constructed some parts in UG NX4 and I’d like to convert them into dxf-files for lasing. 2D-data transferring doesn’t work at my NX4-version (menu item: export data), that’s why I’d like to know if someone knows a freeware version for converting of .prt into .dxf.
    Thanks in advance
    Regards, Martin
    Hello…
    Export of files DWGDXF doesn’t work… what error message do you get?
    Greetings
    <!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--coloro:#FF8C00--><span style="color:#FF8C00"><!--/coloro--><b>Fehler vermeidet man, indem man Erfahrung sammelt. Erfahrung sammelt man, indem man Fehler macht.</b><!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc-->
    Hello
    The error message is:
    “Translation picture not found. The environment variable UGTO2D_DIR was probably incorrectly set.”
    I can’t understand it…
    If there’s an easy bugfixing, I’d certainly prefer a free alternative – that would be the best variant in any case!
    Regards,
    Martin
    Dec 2001
    719
    Hello
    The question is why it doesn’t work. If you bought it, it has to work. You can check in the license file whether DXF stands inside there. If it does, you should set the right variable.
    Regards
    mneubert<br /><br />Siemens PLM Software<br />Technische Vertriebsunterstützung
