586,108 active members*
3,045 visitors online*
Results 1 to 6 of 6
    May 2006
    30
    Angry
    Hello
    How is the measuring probe calibrated at M40 G in Z-direction with a 90°-rptation of the B-axis?
    Jan 2009
    7
    Hello
    You can calibrate it only in x and y unless I'm mistaken. Calibration dataset 1 with – 90°, (axis x/y)
    Calibration dataset 2 with 0° (axis y/z)
    May 2006
    30
    May 2006
    30
    Thanks for the information.
    I received the same information from wfl. Because it’s not a proper 3D probe. But how can I measure e.g. the depth of a blind hole bore?
    Jan 2009
    7
    I’d go back to old virtue and make alignment with a gauge block. I believe there’re not many other possibilities. Or what do you think?
    Jan 2009
    7
    Or let your tool be planned and make then a prdata with renishaw
