586,080 active members*
3,485 visitors online*
Thread: ICS upgrade
    Jun 2005
    477
    Hello
    I’d like to know if it’s possible to retrofit inside coolant supply on a Hermle C800V.
    I now work at the machine with the normal cooling system but I’d like to have ICS.
    So, is it possible? If it is, then how much is it?
    Greetings
    Stefan
    Let there be rock!
    Apr 2002
    5003
    You sure have a parts catalogue. It has everything that has to be made with the spindle. Then you’ll also need a reservoir with a high-pressure pump and filtering. It’ll be the most expensive. I remember that it cost about 13.000€ for my machine (not Hermle). But maybe minimal lubrication is enough for ICS. Then it’ll cot for you about 4000.
