586,072 active members*
4,619 visitors online*
    Hello
    I'd like to know whether it's possible to make data transfer to the machine via PC.
    We now make the transfer with help of perforated tapes. I was said it wouldn’t work with a PC because the old machine isn’t compatible with PCs. Is there however a possibility to make data transfer with help of a pc?
    Thanks in advance!
    Jan 2002
    241
    What controller does the machine have?
    Data transfer works perfectly at my Nef 280 with the old controller Mate Fanuc 3T.
    The machine used to work with a perforated tape reader before.
    I’ve got the software DNC4U
    http://www.dnc4u.com
    It even may be read out with help of a USB serial interface.
    Greetings
    Jean
    Oh, I forgot… epl
    Hello
    It is sure possible.
    You’ll probably need a spooler or whatsisname…
    What kind of gateway do you have between machine and perforated tape?
    Greetings
