586,052 active members*
3,935 visitors online*
Thread: EMO
Results 1 to 7 of 7
    Hello
    I will visit the Emo in a few days and have around 7,5 hours to have a look at cycle turning machines.
    What exhibitors would you recommend?
    Regards
    Rainer
    Jan 2008
    44
    With cycle turning machines I first thought about Weiler
    Hello
    Hall 26 stall G40 and hall 27 stall D45. Emco is represented there.
    The machines run with Fagor cycle controller.
    Maybe that would be a good alternative for you.
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Hello Intex
    Do you know the cycle machines from emco?
    Are they good? How is the Fagor controller?
    Regards
    Hello Intex
    Regards
    I don’t know the once from Emco but our firm has a Pinacho Taurus with Fagor 8055. Easy to handle and completely sufficient for simple work that are between CNC and conventional.
    There is a text version so you can try out the controller.
    Hello
    Can you recommend the Pinacho Taurus?
    I saw that the firm also has a stall on the EMO.
    Maybe I will have a look at it.
    Regards Rainer
    Jan 2019
    No, unfortunately not.
    There is only a flashing light in the alarm window APC, nothing else...
    soundcloud downloader online
