Hello everyone
Where can I buy a 2,2mm VHM cutter? Coated, uncoated,2,3....9 the blade doesn’t matter at this stage.
Regards Manuel
Hello everyone
Regards Manuel
Hello
Grind it!
Regards Boern
<b><br />Das dringendste Problem der Technologie von heute ist nicht mehr die Befriedigung von Grundbedürfnissen und uralten Wünschen der Menschen, sondern die Beseitigung von Übeln und Schäden, welche uns die Technologie von gestern hinterlassen hat.</b><br /><br />Dennis Gabor (1900-79), ungar.-brit. Physiker, Entwickler der Holographie, 1971 Nobelpr.
Hello
For what material and what working depth do you need it for?
Either your tool grinder should be able to do it or maybe some tool supplier can order them
Regards Gerd
Hello Gerd
It’s meant for aluminium and I believe it should mill a 2-3mm deep radial groove. I thought maybe there are suppliers that stock them. I could not find anything so I thought about asking you.
We don’t have the necessary piece number so that it’s worth grinding an extra cutter...4 pieces... in this case we will mill 2 goes with a no.2 cutter... thank you for your help smile.gif
Manuel
Hello
you can get them at Kempf
regards
Kai
