586,115 active members*
3,496 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact Series 1 with TNC 145 can get past PASS OVER *-REF MARK screen
    Jul 2014
    Hello
    I bought an Interact Series 1 with TNC 145 and before I could get it wired up the batteries died and I lost the machine parameters. I found some MP's searching though the forum and entered these. Now when I turn the machine on, I get 'Power Interrupted', I cancel this by pressing CE and then get this screen [can't seem to upload, so have done links instead]
    https://dl.dropboxusercontent.com/u/...Start%20up.jpg
    I can't seem to get it in manual mode at this point - ie. select the handlewheel and ref buttons. It says KEY NON FUNCTIONAL
    https://dl.dropboxusercontent.com/u/...f%20button.jpg
    If I press the top right orange on button and then the white button, it homes the Z axis [I've set it to home the Z axis first [MP17: 5]] and then when I switch axes it says set datum, then it tries to home the Y but runs until it hits the limit switch and trips the relay. [I've taken the cover off the y axis, so I can move it back by pulling on the belt]
    Image of the machine parameters 31-36 https://dl.dropboxusercontent.com/u/...eract%20MP.jpg
    Any advice would be great. Am I missing something really obvious or is there something pretty wrong?
    Thanks in advance
    Tom
    1121
    Re: Bridgeport Interact Series 1 with TNC 145 can get past PASS OVER *-REF MARK scree
    which way is the y homing?
    I believe it homes out on the interacts as opposed to in on the r2c3
    Jul 2014
    Thanks Gus, yes it was homing the wrong way - changed MP's 18,19,20 to ON and 23,24,25 to OFF.
    Spoke to a guy who has a complete list of MP's for the Bridgeport Interact Series 1 with TNC 145, he's emailing over a copy - I'll post them in the MP section once I've got them.
    Cheers
    Tom
  1. Bridgeport series II interact 4
    By skunge in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2013, 07:27 PM
  2. Bridgeport series 2 interact 2
    By Cyphertech in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2012, 05:33 PM
  3. bridgeport series 2 interact 4
    By dcchip in forum Bridgeport / Hardinge Mills
    Last Post: 11-15-2010, 11:47 PM
  4. bridgeport series 2 interact 4
    Last Post: 05-01-2010, 01:27 AM
  5. Need Help Interact Series 1 MK2 strange startup screen
    By BrianP in forum Bridgeport / Hardinge Mills
    Last Post: 07-15-2008, 11:09 PM
