586,072 active members*
4,645 visitors online*
    Jul 2014
    Exclamation I'm new! Question about scorching
    Hi all!
    I'm totally new to all this, thanks in advance for your help!!!
    Dealing with some really bad scorching on a gold metallic acrylic, mostly on the corners of the designs.
    I don't cut the material myself, but my guy that does has told me he's tried every combo to avoid the burning, (20/100/92 done twice seems to work the best but the burns are still visible).
    Do you guys have any advise on a chemical or cleaner to help clean this up? Sanding is difficult because the designs are fairly intricate / delicate. Already tried baking soda, several mild soaps, 3m citrus cleaner to no avail.
    Any thoughts to why this material is so hard to work with?
    thanks again
    Mar 2008
    683
    Re: I'm new! Question about scorching
    Use a single flute cutter. Make a finishing pass. Acrylic need to run fast with a high RPM. Some colors are worse than others. You'll just have to sand it out. The burn is melted in to the plastic.
