586,119 active members*
3,607 visitors online*
    Apr 2009
    16
    Question Leveling pads - steel or rubber?
    All,
    I am finally getting around to setting up my Yamaguchi vertical CNC mill. It has 38mm or 40mm leveling screws, but did not come with any pads. My Mazak lathe came with steel pads that the previous owner made themselves because the leveling screws were jack hammering their way into the concrete. I always had the idea that it should be on rubber pads. What are your guys' thoughts on steel versus rubber? The mill is the same basic model as the one in the link below.
    Yamaguchi Vertical Machining Center
    Aaron
    15362
    Re: Leveling pads - steel or rubber?
    Aaronh
    Steel, they should of had cast or steel foot pad with the original machine, the machine would of never had the jack screws straight onto the concrete when it was new, someone messed up, being an older machine they most likely got lost by who ever moved it
    Mactec54
    Jul 2014
    18
    Steel.
    Feb 2009
    2143
    Steel of a large enough footprint to reduce the pressure so it won't jackhammer in to the concrete.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Apr 2009
    16
    Steel it is. Thanks for the info guys!
  1. Rubber Pads VS Bolts
    By Bob La Londe in forum Uncategorised MetalWorking Machines
    Last Post: 10-03-2012, 06:36 PM
  2. Steel workbench on casters - how to provide leveling?
    By pmurdock in forum MetalWork Discussion
    Last Post: 09-13-2009, 03:35 PM
  3. Bridgeport Mill Leveling Pads
    By minton in forum Bridgeport / Hardinge Mills
    Last Post: 08-15-2009, 05:47 PM
  4. PCB solder pads
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 05-21-2008, 02:53 AM
  5. Sponge Rubber and Diamond plate looking rubber?
    By DennisCNC in forum Community Club House
    Last Post: 06-01-2007, 06:15 PM
