586,655 active members*
2,295 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > The eternal doubt: Spindle, VFD, BOB How to make them speak each other?
Results 1 to 8 of 8
    Jun 2014
    27
    I'm building my first CNC, almost everything it's connect and working except for spindle control.
    I bought a chinese bob but I dont know how to make my spindle, vfd and bob speak each other.
    I manage to connect the VFD and spindle to work manually but I want to use mach 3 to control everything. I'm using a WEG CFW500 VFD I know to configure all the parameters but dont know how to wire the anything from BOB to VFD and spindle.
    Thanks.
    Aug 2003
    494
    Re: The eternal doubt: Spindle, VFD, BOB How to make them speak each other?
    Spindle Control (DigiSpeed) : Homann Designs!, The preferred CNC Component Supplier
    Have a look here at the Homman designs web site and I think the DC-02XL would be close to what you want. Look for the user manual where there is a wealth of info that will get you started.
    I hope it's ok to reference his work here, if not I will delete this post.
    Rich.
    I am not completely useless.......I can always serve as a BAD example.
    May 2009
    36
    Hi did you get this connected ok in the end? could we have a look at the wiring?
    Jun 2014
    27
    Quote Originally Posted by 2e0poz View Post
    Problem solved. The breakout board wasn't working as it should be. I'd replace the bad one and everithing it's ok now.
    Following the wiring diagram:
    https://www.dropbox.com/s/4r9gxgd64s...81%29.pdf?dl=0
    Now I'm trying to implement a charge pump circuit, any tip about that?
    May 2009
    36
    Thanks for that
    I will be running with just 'Enable' to secure systeme on or off. Check my post about this board http://www.cnczone.com/forums/steppe...53852-cnc.html
    Let me know if it helps or not.
    Jun 2014
    27
    I need to tell something else about this board. I dont know why but the 0 to +10v signal it's not a steady signal. In the begining I though that was some kind of interference from VFD but even when I'd turn on the system without the VFD the the signal isn't steady.
    May 2009
    36
    I would try a different GND for the analogue side instead of taking a GND form relay for the VFD
    Jun 2014
    27
    Hi friend,
    Did you manage to make the spindle work with this Bob?
    I could make it start and stop but can't control speed.
    Enviado de meu SM-G900M usando Tapatalk
  1. Eternal's X3 mill build.
    By Eternal in forum Benchtop Machines
    Last Post: 08-24-2010, 07:38 PM
  2. anybody speak Yasnac LX3?
    By Paul in OK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-06-2008, 08:16 PM
  3. Haas Tl-1 Lathe no speak-a the english
    By gromit68 in forum Haas Mills
    Last Post: 10-18-2007, 01:43 PM
  4. Doubt about X2 spindle
    By mugabe in forum Uncategorised MetalWorking Machines
    Last Post: 02-10-2007, 01:48 PM
  5. Do you speak english?
    By cncadmin in forum Community Club House
    Last Post: 05-14-2003, 08:02 PM
