586,693 active members*
2,826 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > 6061 T-6 2"x8" 4th axis milling needed. Have model and sample code. 10pcs minimum.
    Oct 2005
    278
    I have a part that I am currently milling on my cnc BP with a 4th axis. I find that someone with a VMC with a faster spindle could knock these out much faster than I am able to.
    I will not post the drawing/model here as I have a lot invested in this model and do not want it becoming available for free.
    I need a minimum of 10 pieces. I am currently milling from 6061-t6 2.5"x8" round stock. I am open to other machining methods if you have a more efficient manner.
    need these within 30 days. If this proves economical, I will want more.
    Please email nate foerg at gmail dot com for the drawing.
    Note: bidders will be asked to sign a NDA. (via electronic signature through docusign (easy))
    Nate.
    Ann Arbor Meechigan
    Jun 2005
    1015
    Re: 6061 T-6 2"x8" 4th axis milling needed. Have model and sample code. 10pcs minimum
    Nate,
    I tried sending you a PM but your inbox won't receive it. also you didn't leave any contact info on your post. I am in troy Michigan and can sign your NDA. let me know
    Jerry
  1. "Chinese" spindle minimum speed
    By Hirudin in forum Spindles / VFD
    Last Post: 12-21-2019, 01:47 PM
  2. Replies: 21
    Last Post: 01-13-2014, 04:10 AM
  3. Replies: 4
    Last Post: 05-28-2013, 09:20 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
