Hello everybody, and first of all thank you for this space.
Before creating this thread I've been looking for old threads and found a few with the same alarm code, but the difference lies in the spindle drive they had. So here is my problem:
I have an old Mazak QT20 with a Mazatrol T1 control. The spindle drive is FANUC MODEL 15 I think. The number on the drive board is: A20B - 0009 - 0534
The alarm code is number 55 : motor overload. I got this alarm from time to time before, mostly in high humidity days, but It never persisted. Usually I ventilated all the cabinets and a few minutes later the lathe was ready to work.
Yesterday the alarm showed up again, but this time more frequently, and it's impossible to work with the machine. Today the same, I can't reset the alarm, not even switching off the general switch like I always do. There are four leds in the fanuc drive board numbered 1 - 2 - 4 - 8 I think. The 8 and 12 are glowing. I don't have any documentation about this drive, so I don't know for sure where to start.
I have to mention that the first day this problem started we had a problem with one phase in our workshop. The phase was still there, but it couldn't be detected by a multimeter, anyway the machines were working ok. The problem was a faulty lamp that was almost shorted. A strange case, in fact when I used the multimeter to check that phase it showed 0 volts with the tip of the multimeter in contact, and when I retired the tip, for a fraction of a second the voltage raised in the multimeter and then droppend again. I suspect that this has something to do with the malfunction on my lathe, but I'm not sure, anyway I think it's important to mention it. Now the phase problem is corrected, but the lathe still has the alarm.
Anyway, that's the deal, I'm practically without clues, I hope someone can give me a hand to diagnose the problem and take a measure about it because I need this machine to work. I'm even thinking in the worst case scenario (replacing the drive), but first I need to know what's happening there.
Thanks as always for your help and attention!
Leonardo Marsaglia.
