586,105 active members*
3,322 visitors online*
Thread: materials
    Good morning
    Is it possible to say that generally all materials that can be processed machined conventionally, can also be processed with the HSC technology?
    As my previous experienced was mainly with aluminium (which is quite undemanding), I find it a bit tricky to claim that this kind of application is commercially profitable for all materials.
    In this context, I have read that especially cast materials causes troubles.
    Kind regards
    Paulchen
    Oct 2006
    3342
    I am leaning a bit outside the window now and claim that about 75% of all materials can be economically machined that way but there is a group of materials where this doesn’t applicable.
    I am talking about synthetic material and high-alloyed steel ....
    <b><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo-->Gruß General<!--sizec--></span><!--/sizec--></b><br /><br /><br /><br /><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><b>Fräser sind Halbgötter in Blau.<br />Denn sie lassen durch Zerstörung Neues entstehen&#33;&#33;&#33;&#33;</b><!--sizec--></span><!--/sizec--><br /><br /><br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><u>Werbung in eigener Sache:</u><!--sizec--></span><!--/sizec--><br /><i><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->Enter the Matrix an feel the Moment &quot;<u>www.pixxelmatrix.de</u>&quot;<!--sizec--></span><!--/sizec--></i>
    Sep 2019
    75% of all materials can be economically machined that way.
    the impossible quiz
    Jun 2010
    4256
    Re: materials
    As long as the cutter is harder than the material, it can be machined.
    Really hard materials are harder to machine, if you will excuse the pun.
    I have machined ruby and basalt, both of which have Mohr hardnesses of 9. That is harder than most anything you will normally meet - and for that I had to use diamond tooling. Softer materials than that - fine (and HSS is softer).
    Economics don't really come into it. If you need to machine something like HSS, then use the appropriate equipment or do something else.
    Cheers
    Roger
