586,111 active members*
3,522 visitors online*
    Apr 2008
    Hello
    do you have laser parameters for Hardox 400?
    Dec 2007
    86
    Hello
    Do you cut normal blank sheets? How thick is your material?
    Try to set auto las plus by 2 higher. Or the focal point if you don't have auto las plus. Feeding 60-70%, maybe even faster depending on how clean you mirrors are.
    We male lasing with the company Trumpf kA. What exactly do you have? Your information isn't really enough
    We change values depending on the thickness of Hardox. We cut maximally 15mm, doesn't matter whether it's hardox 400 or 500.
    Exactly. I have good experience with it, too.
    As you already said, Hardox can be cut with normal TT. One just should decrease feeding. There aren't any problems even if it was rusted.
