Hello
do you have laser parameters for Hardox 400?
Hello
Hello
Do you cut normal blank sheets? How thick is your material?
Try to set auto las plus by 2 higher. Or the focal point if you don't have auto las plus. Feeding 60-70%, maybe even faster depending on how clean you mirrors are.
We male lasing with the company Trumpf kA. What exactly do you have? Your information isn't really enough
We change values depending on the thickness of Hardox. We cut maximally 15mm, doesn't matter whether it's hardox 400 or 500.
Exactly. I have good experience with it, too.
As you already said, Hardox can be cut with normal TT. One just should decrease feeding. There aren't any problems even if it was rusted.
