586,114 active members*
3,283 visitors online*
    Error during tool changing
    Grabber is on the tool that is taken out from the spindle. The machine stops with the error message E 127 – clamping =O-signal.
    Who could help?
    Hello
    Check the berus of the tool clamp. It has to inform if the clamp is open.
    Greetings mtronik
    <a href='http://www.ersatzteilcenter.net' target='_blank'>Online ersatzteilcenter für Werkzeugmaschinen</a>
    Hello
    Greetings mtronik
    Hello mtronik
    What are berus?
    I removed the hood from the head. The proximity switch has a signal.
    Greetings
    Rainer
    Hello mtronik
    What are berus?
    Greetings
    Rainer
    Hello
    Berus = proximity switch
    Unfortunately I don’t have a connection diagram of MH600 with controller 532.
    You should check whether the signal comes from the proximity switch in the controller. Last week I made repair, the proximity switch glowed but there was no signal.
    Regards, mtronik
