586,103 active members*
3,314 visitors online*
Thread: Deckel FP4NC
    Hello
    I’ve got a Deckel FP4 NC.
    When I run up with 100%, the Z and Y axes make loud noise but the X axis is quiet. What could be the reason? Belt? Tightener?
    Thanks in advance
    Kickinger
    HAAS VF7 - BJ2008<br />HAAS ST20<br />HAAS ST10 mit Stangenlader<br />HAAS Mikron VCE1000<br />EMCO 365<br /><br />www.KDC-Technik.at
    Dec 2008
    106
    Post
    Hello
    In case of my FP4 there was a problem with the brackets of the ball screw. That’s why there was the volume difference. The brackets were changed and it was still then.
    Thanks, I’ll check it up.
    Do you happen to have the numbers of the brackets?
    Greetings
    Kickinger
    Dec 2008
    106
    Greetings
    Kickinger
    The numbers were in the list of spare parts. Standard brackets. Really cheap.
    The company Traumpan mounted them. Everything was ready in one day. But one can make it on one’s own if there’s enough time.
    Regards
    G.
