Re: Can anyone lend some quick tips on lead screws and anti back lash nuts.
The lead screws need to break in. After a good amount of running they will smooth out to a glass like surface. At this point they will have vary little friction and the nuts will last almost forever with no wear.
Unfortunately the break in process will wear the nuts a lot. I ran mine in at too high of a speed and over heated the nuts so they ended up with backlash. I bought a few new ones but ended up making a tap and making a new set of nuts. Now that the screws are broke in I have low backlash and the nuts don't look to be wearing at all.
I have had the router table running for 4 years with the same screws. The 8 TPI screws are a bit slow for a few things and the longer 20" axes do like to whip over 100 IPM speeds.
youtube videos of the G0704 under the name arizonavideo99
