Good day,
I am having trouble finding info on how to calculate a feed rate for a v-bit.
I have a 44.5mm(1.75") diameter V-bit ill be using to to do folds in 3/4 mdf. I was thinking of doing 1 pass at 6 meter a min. 1/2" shank at 15000 or 18000 rpm.
I did a rough calculation from some random guides I could find and found my chip load to be 0.007 or so. That is really low or I just did it wrong.
Should I do 2-3 passes? Use the 18000 rpm ? Or anyone know where I can find straight forward info not relating to compression bits? Or doe sthe bit type not mater?
Thanks as always guys,
Jordan
