586,094 active members*
3,830 visitors online*
    Jun 2014
    13
    Mach3 Break out board question - new machine build
    I am building the first CNC with a BOB found here: http://wiki.midsouthmakers.org/image...axisManual.pdf and have a general question to better understand the principle for operation:
    BOB basically allows to connect to motor drivers via step/dir/enable pins (along with limits, etc.). Why are there additional pins to stepper controllers (white connectors behind the green step/dir/enable bins)? what the purpose of these?
    Also, why is there a 24V power supply connection (in addition to 5v)? 5v should be sufficient for step/dir/enable signals and the 24v should connect directly to stepper controllers, right? Same question about the relay: what does it do since there is no power output to stepper motor drivers (assuming the relay controls the power to the drivers).
    and what is the output to the frequency converter for?
    I know these are very newbe questions but I have been researching this for a while and still came up empty handed. Here is related posts but they do not provide response to my questions:
    http://www.cnczone.com/forums/mach-s...l-mach-v1.html
    Thanks.
    Re: Mach3 Break out board question - new machine build
    The white connectors are the same as the screw terminals, and allow you to use plugs instead of the screws. You'd use either the white plugs or the green screw terminals, but not both.
    The board designer probably chose 24V to allow the use of the motor power supply to power the breakout board. It's actually 12V-24V.
    The relay can be used to turn the spindle on and off, or turn some other device on/off.
    You can use it to control the spindle speed, if your spindle speed controller supports it.
    Jun 2014
    13
    thank you, Garry. Really appreciate
  1. First machine build after 5 year break (pics)
    By painter in forum CNC Wood Router Project Log
    Last Post: 04-08-2013, 04:21 AM
  2. Break out board with mach3 for temp control
    By BTS in forum CNC Machine Related Electronics
    Last Post: 11-13-2012, 07:05 PM
  3. DMM Tech’s DMB3621-4A Mach3 break-out board
    By nytwin1 in forum Dmm Technology
    Last Post: 01-14-2012, 01:51 AM
  4. looking for right break out board
    By christ371 in forum DIY CNC Router Table Machines
    Last Post: 07-22-2008, 11:21 PM
  5. Got a ? on a break out board
    By Ken_Shea in forum CNC Machine Related Electronics
    Last Post: 07-12-2005, 03:44 PM
