586,106 active members*
2,987 visitors online*
Thread: Post Help
    Nov 2004
    26
    Post Help
    Hi, All
    I just purchased a Bridgeport with a boss 8 control. I drew a simple rectangle with a .5 radius on the corners. I am using right tool comp. I get two corners that cut correctly. 1 corner that cuts at a 45 and the other is the start point I think I need a lead in there. As you could guess I an new at this. I have a CNC laser with mach3 that runs fine. Wondering if it is the post?? Bobcad 21
    Gary
    Jan 2006
    4396
    Quote Originally Posted by gguidi
    Hi, All
    Gary
    The post may need a little tweek in the Setup Driver. That doesn't seem like it should be doing that either. If the G-Code is right it should cut all four Radii no problem.
    Post a Cad File and G-Code in the BCC Forum their are a lot of guys there to help you. I don't know anything about a Boss 8 Control
    Post in the BobCad-Cam Forum http://216.117.147.20/bobcadsupport/forums/index.php
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
