Hello all,
Been 'zoning for quite a while now... put together a nice little mill and I'm having good success making custom parts for r/c trucks.
Here's one for the T-maxx and another for the Savage.
I'm looking for someone to make dogbone axles (no lathe :frown: ) , need a batch of 50 pieces to start, hopefully many more.
Material is #304 stainless (you supply), tolerances are very loose except for the ball-ends which must fit into the drive-cups shown.
The dowel pins are 3mm x 16mm hardened steel (Mcmaster #91545A116 - $10.29/100) you supply and press-in to 3mm drilled holes.
I can provide you with a sample axle, drive-cup, and some dowel-pins for test fitting.
Please no amateurs (like the last guy), these will take a pounding and I intend to give a lifetime guarantee... need quality stuff.
You can send quotes to me at [email protected] and please be HONEST with lead times.
Thanks to all, Steve
