586,115 active members*
3,469 visitors online*
    Jul 2014
    Talking ADVICE NEEDED PLEASE
    Hi All. I am a newbie when it comes to cnc routers, having worked with a laser cutter for the past 2 years.
    I am in the process of building a 1.4m x 3m CNC Router/Plasma table
    Using Nema 34 878oz motors, 2 on the X axis and 1 on each of the Y and Z (300mm travel), running on a Mod 1.5 rack .
    I am mounting a 3Kw water cooled spindle and i gues the Gantry weight to be about 25/30kg with everything mounted.
    My question is: Is it nessecary to put a reduction drive from the motor to the rack?
    Can i drive it dirctly or should i use a 4:1 reduction.
    Any advice will be appreciated
    Re: ADVICE NEEDED PLEASE
    The reduction will be smoother, have more power, and will have better resolution.
  1. [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    By baodogg in forum Australia, New Zealand Club House
    Last Post: 06-03-2014, 12:42 PM
  2. VMC advice needed
    By petesurrey in forum CNC Machining Centers
    Last Post: 07-05-2013, 06:48 PM
  3. Help and advice needed please
    By topbuzzhire in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-14-2013, 11:15 PM
  4. advice needed
    By msdeltaguy in forum Vectric
    Last Post: 09-28-2012, 12:30 AM
  5. Material advice and advice needed
    By kiyoukan in forum Mechanical Calculations/Engineering Design
    Last Post: 02-15-2012, 08:20 PM
