586,106 active members*
2,992 visitors online*
    Dec 2012
    10
    RBC Fibroid dry bearings?
    Anyone have any experience with these things?
    The specs look too good to be true.
    A basic 1" ID x 1.125" OD x 1" long CJS1616 has a static load rating of 38,000 lbs and costs less than $8!
    Is there a reason I shouldn't switch all my low speed stuff over to these things?
    http://rbcbearings.com/literature/pd...glide-2013.pdf
    Mar 2006
    2712
    Re: RBC Fibroid dry bearings?
    As long as you can keep the velocity below the recommended surface speed (with some safety factor) for the weight the bearings will see, should be OK.
    Dick Z
    DZASTR
    Dec 2012
    10
    I've decided to use them exclusively in a new hydraulic mechanism I am getting ready to prototype.
    I noticed the wear testing they did was quite a bit below the load capacity they advertised, so I'll be equally conservative where possible.
    I also saw they spec a hard smooth surface to wear on. I decided be a bit overly conservative again and to just use hydraulic rod stock for the shafts, and skip fine machining and surface treatments.
    I'll report back after some testing.
    Mar 2006
    2712
    Check the material spec's. Some perform better if lubed, some swell if lubed. Is the bearing going to see contact with hydraulic oil?
    Dick Z
    DZASTR
  1. Bearings
    By jjacstcy in forum DIY CNC Router Table Machines
    Last Post: 03-10-2011, 01:44 AM
  2. skate bearings versus linear bearings
    By paul langwade in forum Linear and Rotary Motion
    Last Post: 05-29-2006, 04:06 PM
  3. Double Bearings Or Quad Bearings?
    By ballscrewed in forum Mechanical Calculations/Engineering Design
    Last Post: 04-18-2006, 06:33 PM
  4. Bearings (Radial Ball Bearings)
    By The Bearing Man in forum Community Club House
    Last Post: 12-18-2005, 07:10 PM
