586,047 active members*
3,903 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Please Help - Need sample file ASAP
    Jan 2011
    9
    Hello:
    I have a 3 axis CNC machine. Honestly I just never learned to use the software due to moving and medical problems. Have to
    move again but this time into a small apartment. My CNC machine is all configured with Mach3. I have a guy coming over to
    take a look at it but I need a simple file such as a square just to show him that the machine runs. I informed him that the machine
    probably needs fine tuning but even when I run one of the sample files the machine sounds rough. Even though I've informed
    him of this I'd like to run a program that shows the X, Y axis accepting commands from file. I can control each axis through Mach3
    but I would really like to run a simple program for him.
    If someone could point me in the direction of downloading a simple square pattern I would appreciate it greatly.
    David
    Jan 2015
    Re: Please Help - Need sample file ASAP
    for a simple file to run you have mach3 go to wizard tab and select one that is how i programed mine at first good luck
  1. Sample 3D Output File Zund Controller
    By jxuereb in forum EnRoute
    Last Post: 06-20-2019, 12:58 PM
  2. Importing Sample 3D Rhino File
    By aseylys in forum LinuxCNC (formerly EMC2)
    Last Post: 06-08-2014, 07:02 PM
  3. learn 5 axis camworks need sample file
    By plast744 in forum CamWorks
    Last Post: 05-13-2010, 11:24 AM
  4. Sample file of stamp with few security features
    By Litografa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2010, 10:38 AM
  5. sample file for Heidenhain
    By Tulak in forum Uncategorised MetalWorking Machines
    Last Post: 06-16-2004, 05:41 PM
