586,060 active members*
4,167 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > mach3 crashing with run of code/drilling holes through table with other code
    Jun 2012
    4
    I've recently been having issues with mach 3 lately. On startup of mach3 with a loading of any gcode, as soon as I hit run the code will go for a few lines, the machine will move, stutter once, then mach 3 crashes and loses control of the machine which will stop. Boot up mach 3 again, no control of machine, close and start up again, mach3 has control of machine again. Load gcode, run, completes perfectly every time regardless of amount of re-runs with 0 problems.
    Here's where the next big problem lies. After running a successful toolpath, if I close down that gcode and load another one, at some part of the run with the new code the machine will abruptly stop X Y movement and lower the Z directly into the part/table and lose mach3 control. This Z axis drop will usually occur at the same part of the gcode, but I've observed it occurring at different areas. On occasion even with jogging the loss of control/sudden drilling of table will occur.
    I've practically ruled out machine errors, post-processor errors, controller errors, and I'm starting to think it's the computer that's running mach3. The machine never encountered problems of this variety with a previous computer but the motherboard gave into age. Any help with any one of these problems would be immensely appreciated, as it's holding me back on doing certain jobs.
    machine- CRP4848 / G540 if that matters in this instance.
    Feb 2007
    4553
    Re: mach3 crashing with run of code/drilling holes through table with other code
    Have you implemented the XP System Optimization Guide?
    Windows XP Professional System Optimization Guide:
    0. Install Windows in Standard PC Mode
    1. When you see the installation tell you to press F6 (Third Party
    SCSI or RAID Drivers) press F5 instead.
    2. You will see Press F2 for Automated System Recovery, (DONT press
    F2).
    3. Right after that you will see a list.
    4. Press the UP arrow key to highlight Standard PC.
    When installing, make SURE you install all of the most recent drivers
    for your
    Hardware. This is vital!
    6. Disable Automatic Updates
    1. Right Click My Computer and select Properties
    2. Click Automatic Updates tab.
    3. Uncheck Keep my computer updated..
    4. Click OK.
    7. Disable Remote Assistance
    2. Click Remote tab.
    3. Uncheck "Allow Remote Assistance Invitations.".
    4. Click OK.
    9. Set Computer to Standard PC NOT ACPI PC
    NOTE: This is only necessary if you wish to remove ACPI AFTER install.
    If you followed step 0, you don't need to do this.
    2. Click Hardware tab.
    3. Click Device Manager Button in the middle.
    4. Double click "Computer".
    5. Right click on Standard ACPI PC and choose Update Driver.
    6. Choose "Install the software from a Specific Location (Advanced)"
    7. Click Next.
    8. Choose "Don't search. I will choose driver to install."
    9. Click Next.
    10. Choose "Standard PC" from the listing.
    11. Click Next.
    12. Click OK.
    11. Disable Startup Items in Registry
    1. Click Start button.
    2. Click Run.
    3. Type MSCONFIG and press [ENTER].
    4. Click Startup tab.
    5. Uncheck everything
    6. Click OK.
    7. Exit MSCONFIG.
    12. Disable Startup Program Group Items in Start Menu
    1. Right click Start button and choose Open.
    2. Double click Programs.
    3. Double click Startup.
    4. Delete anything you think you don't need.
    5. Close window.
    16. Set Windows Theme to CLASSIC
    1. Right-click on your desktop, and then click Properties.
    2. Click on Themes tab
    3. Set Themes to Windows Classic
    4. Hit OK
    17. Disable Indexing on all NTFS drives
    1. Double click My Computer.
    2. Right click on hard drive and choose Properties.
    3. On bottom, uncheck "Allow Indexing Service to index this file for
    faster searching". 4. Hit OK.
    18. Run diskperf -n (Turns off disk performance monitor)
    1. Click the Start Button.
    2. Click Run.
    3. Type DISKPERF -N and press [ENTER].
    20. Disable MSN Messenger
    1. Double click on the Messenger icon in the system tray to open it.
    2. Skip thru the internet and sign up stuff, just cancel it.
    3. When Messenger loads go to Tools -> Options then Preferences.
    4. Uncheck 'Run this program when windows starts'
    21. Disable Power Management
    2. Click on the Screen Saver tab.
    3. Set Screensaver to None.
    4. Press the Power button near the bottom.
    5. Set all options to NEVER shut down automatically!
    22. Disable Wallpaper
    2. Click on the Desktop tab.
    3. Where it says Background, scroll all the way up and choose None.
    4. Click OK.
    23. Disable System Sounds
    1. Click Start Button.
    2. Click Settings.
    3. Click Control Panel
    4. Double click Sounds and Audio Devices.
    5. Click Sounds tab.
    6. For Sound Scheme, choose "No Sounds".
    7. Click OK.
    25. Install Programs
    Do not install any programs you will not use. Only install programs
    that you DEPEND on for what you do on your computer. Keeping things
    lean and mean will keep your system fast and stable.
    26. Maintain Hard disk
    1. Double click on My Computer.
    2. Right click on Hard Disk and choose Properties.
    3. Click Tools tab.
    4. For Error Checking click Check Now. Do before Defrag!
    5. Click Defragment Now, AFTER Error Checking completes.
    6. Click OK.
    27. Disable Ballon tips
    1. Click Start - Run and type Regedit followed by enter
    2. Navigate to
    Hkey_Current_User\Software|Microsoft\Windows\Curre ntVersion\Explorer\Advanced
    3. Click Edit - New - Dword value and create a new Dword called EnableBallonTips - Enter
    Double click on it and set value date field to 0 (Zero) typing 1 (one) will restore it
    28. How to change the default file naming from upper case to lower case
    2. Navigate to
    3. Double click on Dword DontPrettyPath and change value to 1 (one)
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. Image to G-Code for drilling
    By neodd70 in forum Uncategorised CAM Discussion
    Last Post: 07-13-2014, 02:08 AM
  2. Replies: 26
    Last Post: 06-20-2012, 11:18 PM
  3. Replies: 0
    Last Post: 09-09-2010, 07:28 AM
  4. 3D drilling - G80 code missing
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-14-2008, 08:00 AM
  5. G-Code Contouring/Drilling
    By tjones in forum Tutorials
    Last Post: 01-09-2006, 04:20 PM
