586,913 active members*
2,876 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > LaserDRW & LaserCut - Is There a Difference?
    Jul 2014
    I've been looking at Chinese laser cutters and have seen some as coming with LaserDRW and some with LaserCut. Both seem to be compatible with CorelDraw. Is there a difference between the two? And if so, exactly what is it? In particular, is the range of CorelDraw versions that work with LaserCut (11-X4 from what I can tell) different from those that work with LaserDRW?
    Any help deciphering this mystery would be much appreciated.
    Re: LaserDRW & LaserCut - Is There a Difference?
    lasercut is better in engraving while LaserDRW is better in cutting
    hope this will help you
    tina from g.weike laser
    EMAIL: [email protected] SKYPE: lysunshine521
    Apr 2015
    LaserDRW does not require CorelDraw; it is an independent program. Now, as it happens, I *did* need a copy of CorelDraw to use LaserDRW to cut. For engraving, LaserDRW will load a variety of raster formats: jpeg, gif, png, and whatnot. But for cutting, the ONLY vector format file it comprehends is WMF, Windows Metaformat, or the extended version. Since none of my pro-level Macintosh software exports .WMF files, I end up exporting .ai or .pdf files, loading them into CorelDraw on the Windows box, exporting them as .wmf or .emf (I haven't been able to identify any significant difference between the two formats), and then loading that into LaserDRW.
    I have also tried using the CorelDraw plug-in. The result is a control panel very similar to the one in LaserDRW, but without the initialization screen. I don't like it as well.
  1. LaserDRW help
    By Col182 in forum Laser Control Software
    Last Post: 01-24-2015, 09:24 PM
  2. 40w ebay Laser - LaserDRW program woes
    By meltonio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-22-2014, 11:21 PM
  3. CorelLaser/LaserDRW extremely inefficient paths
    By BitcoinWallets in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-12-2014, 12:18 PM
  4. LaserCut 5.3 DPI
    By cdmcali in forum LaserCut
    Last Post: 02-18-2013, 09:40 PM
  5. lasercut
    By LOLO80 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-11-2009, 01:56 PM
