586,112 active members*
3,111 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Installed a probe z-touchplate; now machine is going crazy on tool change (mach blue)
    Sep 2011
    26
    So I installed a touchplate which recommends using the mach blue screen.
    Pretty simple inputs, touch the wire to the plate; green light on the probe setting comes on like it should. The problem is when i hit the auto-z button; the router will go down a little slowly, then just drives itself into the material very quickly. The light is on so the circuit completes, but doesnt ever stop itself.
    That's problem 1. Problem 2 is running my previous G-codes, which I believe is on a tool change command wants to drive the router way out off of its limits in the x/y direction. I have the tool change location set to 10/10/3.... so i'm not sure what is causing this.
    None of this happened before the mach blue install, uninstalling it doesnt help the situation.
    Re: Installed a probe z-touchplate; now machine is going crazy on tool change (mach b
    Problem #1 is an issue with the auto zero macro.
    Problem #2 is probably an issue with the M6 macros.
    It may be that you are missing some settings in the screenset that the macros use??
    Jan 2009
    72
    Hi czwalga,
    I have tried many screens and the best by far in MY opinion is
    Once set up it works as it should every time.
    No affiliation blah blah blah
    Cheers
  1. Z axis is going crazy! "Mach Blue screenset"
    By Claytonc in forum Uncategorised WoodWorking Machines
    Last Post: 01-27-2021, 09:33 AM
  2. mach wanders off after tool change
    By dertsap in forum Mach Mill
    Last Post: 02-10-2014, 04:36 AM
  3. Mach3 and Auto Tool Zero / Mach Blue Probing by Big-Tex
    By TomiY in forum Machines running Mach Software
    Last Post: 11-15-2012, 09:24 PM
  4. Replies: 4
    Last Post: 02-01-2011, 03:10 PM
