586,112 active members*
3,168 visitors online*
    18
    Laser cutting Delrin, getting sloping edges
    I have a cheap Chinese 80 watt CO2 laser and I’m getting a sloping cut when I cut or engrave 1/8” thick Delrin plastic. I don’t know the focal length of the lenses my laser came with. The cut is V shaped so that the slot at the bottom of the material is much smaller than at the top. Is there a work around for this? I’ve tried cutting in stages at lower power all to no avail, any suggestions?
    Brian
    Nov 2012
    492
    Re: Laser cutting Delrin, getting sloping edges
    try focusing in the middle of the material.
  1. CNC Laser Cutting - Edges not square ??
    By Just-In-Kase in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-02-2015, 09:12 PM
  2. Cutting Delrin (Acetal) with Laser Cutter...
    By TurkishDelight in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-05-2012, 05:46 PM
  3. What causes "rough" edges when laser cutting acrylic?
    By shobley in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-28-2011, 12:19 PM
  4. Laser Cutting 3/8" White Acrylic & Getting Burned Edges
    By RJlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-06-2010, 04:52 PM
  5. Cutting chamfered edges
    By 80083r in forum EdgeCam
    Last Post: 08-13-2009, 01:09 PM
