586,103 active members*
3,404 visitors online*
IndustryArena Forum > CAM Software > OneCNC > Can OneCNC post line numbers with - a) decimals? or b)restart from 0 after a set max?
    Apr 2005
    345
    Trying to DNC some very long programs to a Dynapath delta 20 , which is limited to 9,999.999 lines of code.
    Dynapath has given me two options, as described in the Title - either to post with decimals (the control can read 9999.999) and increment in steps of .001 or so........or have the post restart from zero when it gets to 9999.
    Anyone able to do either of these within the postprocessor of OneCNC? I know I could always renumber manually....
    http://www.scpconcepts.com
    927
    Re: Can OneCNC post line numbers with - a) decimals? or b)restart from 0 after a set
    Z,
    Sorry I didn't think of this before . Just set your field width to 4 and you are good to go.
    That will got to N9999 then restart at N1.
    Reposted this on the OneCNC forum too..
    Apr 2005
    345
    Huge HUG to you WMS, can't believe it , was trying larger size fields haha.
    THANKS!!!!!!!!!!!
  1. Restart in line that is more than 1 million
    By SigR in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2013, 03:54 AM
  2. Line Numbers
    By qnet2 in forum Post Processors for MC
    Last Post: 12-08-2010, 04:39 PM
  3. no line numbers
    By weirdharold in forum UG NX
    Last Post: 01-22-2009, 04:42 PM
  4. Line numbers
    By Eritex Inc. in forum Mastercam
    Last Post: 12-13-2008, 04:35 AM
  5. Line numbers
    By batmill in forum G-Code Programing
    Last Post: 09-16-2007, 09:25 AM
