Hey everyone, I could really use some help with my project.
I'm trying to cut some shapes into formica with my 5x10 home built CNC. They're pretty small and detailed pieces, each one measuring only 2.25" wide and 96" long. The material is called formica, it's used for cabinet facings kind of like a laminate. The material can be found here: Brushed Aluminum
Quick Overview
DecoMetal laminates and solid metals come in lustrous colors that go from cool anthracite to dusky burnished copper in textures that project energy, modernity and a feel for for craftsmanship. Suitable for light duty horizontal or vertical applications: walls, furniture, retail fixtures, signage, exhibits and displays.
Anyways, I tried cutting it using an up cut 1/6" router bit with the good side of the formica facing down. It has a kind of cork or mdf backing on the material with a very thin aluminum face. My problem is that my router bit is pulling up all of the edges, on the back and the front. The back I can just sand down but I can't do the same on the front as I'll ruin the nice finish. I can't sand the edges because they're so small.
My feedrate is 60 ipm, plunging 0.08" (the material is only 0.045" thick) and doing it all in one pass. I don't have a vacuum hold or anything, so I'm just clamping down the material on the table on one side along the length.
Here's a few pics of my test piece. Each one of these rows is supposed to be cut down into strips. I didn't see the point of cutting them cause they turned out so bad.
On the first pic, even the jaw of the horse on the bottom was broken off from the router bit pulling.
Any help with the different setting to try would be appreciated.
