586,047 active members*
3,772 visitors online*
Results 1 to 7 of 7
    Oct 2004
    39
    Rfq Machined Aluminum Plate
    Hello everyone,
    This is for a telescope project I am working on. I do not have the time or space on my CNC mill to do this so I wanted to see if anyone was interested in quoting. I attached a .dxf and jpg 3D image. Email me for a Solid Works file. The material will be .250" thickness aluminum, any grade is fine. Finish is not critical, but clean would be nice. The three holes are to be tapped 3/8-16 2b typical. There is also a .0625 chamfer around all edges on both sides. Please provide quote and lead time. I'm in no rush. Thank you. Any questions please send them to me. I only need one unit made right now.
    Regards,
    Phil
    Attached Files Attached Files
    Apr 2006
    100
    E-mail me the Solidworks file And I'll quote this for you.
    Thanks Mike
    [email protected]
    [email protected]
    www.hessemachine.com
    Apr 2005
    345
    Phil - can you save it as an IGES or STEP file? Send it to zcases<at>frontiernet.net
    Scott
    Apr 2005
    345
    Actually if I just knew the OD I could give you a price from that.
    Scott
    OD is 10 inch
    Apr 2005
    345
    Thanks Solgood........Philip I will PM you soon.........
    Oct 2004
    39
    RFQ Machined aluminum plate
    Hello everyone,
    Thank you all for your time and responses to this post. I have decide on a vendor and this quote is now closed. Thank you.
    Regards,
    Phil
