586,096 active members*
3,012 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Angled walls with chamfer mill?
Results 1 to 20 of 25
Threaded View
    Feb 2006
    198
    I've got a project where I need an angled wall in 6AL-4V, with one setup, so I can't use a sine-vise, or other method of tilting the work piece. I've attached an example .igs (in the zip) file showing a 60 degree wall. I've bought one of these Chamfer Mill and would like to use it to finish the 60 degree wall. I'm using v26 pro. Ideally, I'd rough it with a square end-mill then finish the wall by walking down it with the chamfer mill. I can't figure out an "easy" way to do that since 3D machining doesn't seem to support "V-bits" like the V-Carve section, or 2D chamfer tool path does. Right now, I'm considering.
    1. Use 3D advanded roughing to hog most of the wall with a square end mill, leaving steps in the wall.
    2. Use the simulator to then create an .stl file of the workpeice after the first operation.
    3. Extract edges from the .stl "rest machining" file and do 2D chamfering on the extracted edges of the steps left from #1.
    Is there an easier way?
    -Jim
    Attached Files Attached Files
  1. Chamfer hole located on an angled
    By colby2000 in forum CNC Swiss Screw Machines
    Last Post: 04-17-2014, 08:34 PM
  2. V25 Mill Radius Edge Break On Angled Feature
    By JoeCraftsman in forum BobCad-Cam
    Last Post: 02-09-2013, 09:36 PM
  3. can i peel mill with tapered walls?
    By poster in forum Mastercam
    Last Post: 03-10-2012, 06:52 PM
  4. Chamfer chamfer mill or ball mill
    By fjbart70 in forum Mastercam
    Last Post: 03-11-2011, 06:27 PM
